Use this procedure if you want the switch to support advanced features. When you enable the boot flag, you need to save and reboot with the new configuration.
This procedure only applies to VSP 7400 Series.
Product Notice: For VSP 7400 Series, you must ensure your configuration does not include reserved ports before you enable this feature. If the configuration includes reserved ports after you enable this feature and restart the switch, the switch stops loading the configuration.
A message displays to remind you that the configuration cannot include reserved ports, and that you must save the configuration and reboot the switch for changes to take effect.
If you selected No, you can modify your switch configuration to remove the reserved ports and then return to this tab to change the AdvancedFeatureBWReservation configuration.
